I want to make winterizing easier.
    On my 2003 245 the winterizing process includes removing the seawater pump inlet hose from the pump for draining. I have very little access room in my engine compartment and removing this hose is always a big pain in the a$$. All the other drains have that blue drain plug that is easy to access and remove. So I would like the same blue drain plug on the seawater pump inlet hose. Is there such a hose coupler that has the drain plug port? I could just cut the seawater hose in half at the lowest point for draining and install the coupler.
    2003 Bayliner 245
    2007 Sedona F21
    Well, I looked at other mercruiser engines and found what I think will work. Drain Insert #861505.
Name:	drain insert.JPG
    2003 Bayliner 245
    2007 Sedona F21
      This will work
      2003 Bayliner 245
      2007 Sedona F21
