RPM(39)s Speed and prop pitch choice-gctid403468
    Hey Guys I need a little help. On plane cruising I'm running at around 3700 rpms at aroung 21-22.5 mph depending on wind. The boat is a Contessa Sunbridge 2850 with a single 350 and a 280 volvo single prop drive.The prop is a 15 x 16. First is this a normal running rpm for a single? Would it help raise the pitch? I'm not sure what the WOT rpm is I'm guessing around 4300-4400 I know I've seen at least 4000.
    Thanks for any help Brian.
    I have the same boat, originally with a SP 280. I went to a 16 x 13 prop and it made a HUGE difference. I now have a DP running B 2's. On plain at under 3000 and have topped out under ideal conditions at 39 MPH. WOT for that boat, with a 260A is 4400 RPM.
    Tony, Cape Cod, MA
    Vice Commodore Bourne Yacht Club
    1994 Carver 390 Cockpit Motor Yacht
    454 Merc Cruisers inboards
    "HOLODECK"
    2014 10' hard bottomed Dink powered by 3.3HP Mariner 2 stroke
    www.bourneyachtclub.com
