One of my hoses is leaking. It looks like it was replaced before as it doesn't match the rest and it's probably a cheap one cause well.... it's leaking..Anyway, I can't seem to locate my specific setup. Mercruiser 470 outdrive. I have seen many diagrams but they aren't showing the specific hoses I have.Particularly there are FOUR hoses, and BOTH hoses on each side attach next to each other on the trim cylinder. They are about 12" long and 3/8 diameter hoses.The main configurations seem to be only two hoses (one port and one starboard) or when there are 4 hoses, a pair on each side connect to each end of the cylinder or to an solid extension.Here is what mine looks like...
[img]/media/kunena/attachments/vb/707014=30011-hoses1.jpg[/img]
[img]/media/kunena/attachments/vb/707014=30012-hoses2.jpg[/img]Also, as I want to AVOID whatever the hose on the right is made of... does anyone have any insight into the material. The one on the left matches the color and wear of the two hoses on the starboard side. They seem fine, intact and high quality. They are a dull but stainless looking finish. The one on the right is shinier. You can sorta see where the crimp has failed. I want to avoid whatever this hose is, but I need to replace it.As stated above, I have not been able to locate this configuration for a part number to look up.Thanks in advance..
