Steering and cable Teleflex for Bayliner Capri 2350 1999 year?
    What new numbering of the steering and telex cable for Bayliner Capri 2350 1999 year?
    Can anyone with experience help me?
      On your current cable there are a series of numbers, one of which is the length. SeaStar Marine is the marketing arm and are really helpful in getting the correct replacement parts identified, but you are going to need the numbers. http://www.seastarsolutions.com/
        The numbers are completely erased
          Okay, are the numbers gone at both ends of the cable? If so, and since you are going to have to replace it anyway, if it were me, I’d remove the cable from the boat and lay it out in as straight a line as you can and measure the length of the housing. I’m reasonably sure it’s a rack and pinion type so there will be four bolts holding the rack to the steering wheel assembly. Disconnect the engine end then feed the cable forward. There are lots of cable ties to be cut and replaced. Once you have it out, pm me a picture and we can figure out a proper replacement.
