Replacing Anodes Early?
    I'm running a Bravo 3 leg on my Ciera 2455. I went out to check the boat the other day (sit in the water year round) and noticed one of my lift ram anodes is now gone. I wasn't planning to do a haul out for a month or so, where I was going to replace all the anodes. What's the advise here? Can i just unplug the boat, reach down into the water and bolt on a new one to get me through a month? I'd hate to spend $300 twice this year to haul out the boat. I'll also need to to bottom paint and a wax which would take a weekend where I just don't have the time to do until the end of March
    Thanks.
    2001 Bayliner Ciera 2455 5.7 Merc MPI, Bravo 3
    2009 Subaru WRX STI
    2017 stick with a nail on the end of it
    Victoria, BC
    Assuming your 2455 is moored in salt water...
    all depends how brackish your marina is.
    we recommend every 6 months on B3.
    My advice would be look for a trailer.
      Keep a calendar of how often you replace your zincs, how much erosion and the general condition. Just unplugging you boat isn’t going to help much, it has more to do with the dock power and boats around you.
      Get a zinc on that lift ram right now and make sure it has good contact and is tight.
      Next, take a multimeter and check the milivolts occurring around your boat. Extent the positive lead into the water a couple of feet, I use some primary wire with about 6” bared at the water end, then ground the other end to a known ground on the boat. Someone will chime in with the max reading, but it’s low. Here’s a decent explanation https://s3-ap-southeast-1.amazonaws....03b8249d8c.pdf
      On my last boat I had the mercathode system that seemed to help in my particular case.
        Did it get eaten away or fall off? It’s fine to replace the missing anode while it’s in the water, check the bonding kit on that one trim ram but as Joon pointed out you’ll want to keep up on those anodes when your moored up most of the time.
        "THE FIX"
        Misc. projects thread
          It fell off when I took a brush to remove some seaweed that was wrapped around the leg. I could see it sink to the bottom. The anode on the other ram is still there, along with the plate anode. The trim tab anodes still look really good too. I think I might go out and get a half lift at the local marina so I can replace these on the weekend.
          2009 Subaru WRX STI
          Victoria, BC
            You got some good advice. Check all of the wires that make up the continuity pack. If all the wires are intact, don't pull the boat, you can get it with the drive lifted. If any of the wires are missing, I'd replace them and get fresh zinc. Make sure your MercCathode is connected.
            Check out Section 7 of this pdf: http://www.ta-group.at/dokus/service...avo_drives.pdf
            Tally and Vicki
            "Wickus" Meridian 341
            MMSI 338014939
              Thanks for the advice everyone. I had a full rebuild of my leg a year ago and one of the thing we did was go through all the grounding wires to make sure they were good and attached properly. Reason being was that I had a grounding wire that was not attached by another mechanic I used and this caused some major electrolysis of some expensive parts on the bravo 3 (gimbal ring, transom pate, and all the hardware) which was all replaced. So i know the wiring has been installed correctly. I ended up going over to the marina next door and got the boat on the hoists and replaced the anodes myself. Turned out to be a nice day to do an easy job.
              I do a have another question. this is the first time I did my own anodes. I did a bit of research and talked to the guy at the shop when I bought my kit. It came with the anodes similar to below. Now, on all the photos I saw online, there should have been 2 plate anodes that are placed up under the plate portion of the leg just above the props. On my Bravo 3, I only had one. Was mine a different year model than a newer one? I believe my leg is the original that came with the boat in 2001.
              2009 Subaru WRX STI
              Victoria, BC
                After 2004 they went to two instead of one.
                2007 285
                350 mpi b3
                Vancouver BC
                  Yup & aluminum anodes on B3s.
