bought this boat a couple months ago and did some repairs to the heads, it had broken springs and a broke push rod so I pulled the head to repair, it runs great now BUUUUUUUTTTTTTT when I add water to the riser manifold tank or whatever its called with the radiator cap it disapears in less than a minute then I add more water and it goes somewhere. I had the exhaust manifold and riser apart and they looked ok,no water in the oil whatsoever, that leaves the heat exchanger? I am also running kind of hot, how do you troubleshoot these systems and has anyone ever removed the closed cooling on one of the engines and ran it that way, I have never had a boat with closed cooling because I flush my engines for 45 minutes after running with salt water, everyone I know has had trouble with closed cooling so I have never wanted a boat with closed cooling.
I would prefer to just remove the closed cooling and make it raw water cooled, these engined came this way and have a lot of hoses run every where for cooling, any suggestions.
