So I went and ordered a slew of u-bolts for my trailer (for my 2452), and realized that I needed 1/2" diameter rather than the 7/16" that I ordered! These are the ubolts that hold the wobble roller assemblies to the trailer, so structurally they seem important as the boat is forced all directions while moving down the road. Will the slightly smaller bolts I ordered be strong enough???
Wrong size U-bolts-gctid348403
That size would be fine for rollers.
Now if it was the "U" bolts for, say, an axle, then no not ok.
I would say use "em!
I thought I'd bump this back to the top to see if I could get any more input before I install these tomorrow. I tend to agree with Jeff, but I just want to make sure I'm not setting myself up for a bad situation!
