Need ID help!
    Need ID help!
    Thanks for the invite,Picking this up for $600.oo, Any help would appreciate ,Like should I pass on it?motor is strong seem to be all there 4cyc Penta Thanks
    If it floats and runs, and it has a trailer, AND you like it, that's worth a grand all day long. Welcome to the BOC!
    Jeff & Tara (And Hobie too)
    Lake Havasu City, AZ
    And 13 others...
    • Jahbass
      Jahbass commented
      Thanks So much,I’m looking for any help........
    It's a 21xx Explorer, semi- displacement hull, the 4 banger is there for a specific reason.
    " WET EVER "
    mmsi 338108404
    mmsi 338124956
    • Jahbass
      Jahbass commented
      What specific reason?What is a diplacement Hull? I have not been able to find any Bayliner (Exploroer)
    Does anyone know what this # mean ....
      Yes, that is the Hull Identification Number. You can get all the manufactured information about the boat from this number. See https://itstillruns.com/decode-bayli...-10040889.html
      • Jahbass
        Jahbass commented
        So is it an 2004 or the last #. 1983? Sorry,it confusing because my Ser# so different ,don’t fit the profiling ...BL BA 62FDO483-3
      Thank you SOoooo much, I’m glad I joined this group U’s guys are so helpful.......MUCH THANKS
        Looks like a Marysville WA plant boat (BLBA) - Hull made in April-83.
        MY 3988
        M/V MMPOWRD
        Poulsbo, WA
        • Jahbass
          Jahbass commented
          Bay39,Thank you so much ....
        Built at the Arlington plant and was the 62nd of the model (FD) built during the model year.
        • Jahbass
          Jahbass commented
          Woodiver,That Great,Thank you ....
        Thanks for all the Help,It has been ID,1983 Bayliner Trophy 2260 ,Aq125 ,270 Outdrive
          Congrats. Make sure you change all fluids, check bellows (probably worth changing unless proof they have been done recently). Tune up is a good idea as well.
          1998 3055 Ciera
          (yes, a 1998)
          Previous boat: 1993 3055
          Sea Doo XP
          Sea Doo GTI SE
          • Jahbass
            Jahbass commented
            Sound like a Great plan...will do.
          Pull the plugs.. Squirt fogging oil in the cylinders. Let sit for hours. Turn over the engine with a wrench while the plugs are out. It should turn easily. If not, reverse the rotation a little and then forward. If it has been sitting for several years, the cylinder walls may have slight corrosion. If you don't do the above, you could risk breaking a piston ring. ,
          cglazier - "Fiftybucks"
          1995 2855 7.4 bravo II
            I am definitely going to do that, that sounds great! Thank You.If I may one more thing,I have a GOOD AQ125 in the Boat now with the 270 OutDriver... A buddy of mine offered me a AQ130 with the 270 Outdrive for back up. I read one time in the forum a couple days ago that all AQ four cylinders are Enter changeable,,Does that sound right in your opinion.....
              What do you have aq125a or aq125b?
              125a is B21 block, 125b is B230 block.
              aq125 , aq130 engine parts won't be interchangeable, but both engines will mate to a 270.
              • Jahbass
                Jahbass commented
                Sorry AQ125A
              That sounds great! I will be able to use the AQ130 and have an extra outdrive for the boat...SWEET! I was hoping to just put it in my garage slowly rebuild it paint it up nice, get it running and have it in case I ever need another motor these things are getting harder and harder to find ...Really appreciate all your help thanks
                Up date,Will she coming along....
