Steering cable replacement on 1992 trophy with 150 Mercury outboard
    Do I need to remove outboard to install new cable? Looks really tight space
    Yes you will need to lift the engine off of the transom to slide out the steering cable out of the tilt tube but only a little way as I just did my steering and my OB has to be slid back a little bit but had to take out the four bolts that holds the engine on and resealed the bolts when reinstalling and my engine was on a hoist of course.
