I'm curious about the mention of disconnecting the ACR... and am I going to need to do something regarding it beyond the instructions it came with? My setup is 1 start, 2 true deeps for house wired in parallel, BlueSeas Combiner with ACR and Pro Mariner Elite 360 3 bank connected to the shore power beaker box. Even though the 2 house deeps are in parallel, the tech rep at ProMariner said give each one a set of leads from the charger. Also have a 3000W gen I plan on running to the A/C shore power inlet (and my CPAP from it's wall plug outlet) for overnight on the hook and in the AM if I'm staying put the day swap SH/PWR inlets to . If that wasn't enough, I have two 4"X12" solar panels, one for the start batt and the other.....planning on connecting in typical parallel config. mainly for keeping topped off during extended absence and planning on making that connection switched on my MBSS panel and connecting to terminal tabs along with bilge pumps attached to the main posts so I can leave MBSS off. I'm starting to confuse myself so I'll await some advice/ opinion. Still have to get at the existing wiring which had a 2 batt 2 bank setup, judging from the batt box "shadows" and an original 30 amp charger and off/1/2/both MBSS, but when we ran the engine and ops checked the systems there were no batteries and someone had zip tied all the negatives together and same with positive leads and used a 12V charger for power so I've got quite a task ahead for warmer weather. That I can handle but am confused about the ACR
