Leaking front cabin windows - 2452-gctid402425
    Anybody know how to fix leaking front cabin windows on the 2452. Water is leaking slowly through the perimeter seal, and causing mildew on the carpet liner in the cabin where it drips down. I've tried Captain Trolley's Creeping Crack Cure, but that stuff just runs right down the outside the seal withough penetrating anything, so it doesn't work...
    remove window and seal properly?
      I guess that would be the only non-bandaid solution. I'll probably just check out an auto glass repair place rather than do it myself.
