Dual Pro Charging Systems charger with Blue Seas ACR
    I just bought a dual charger to install in my boat, a 195 bowrider. I have two batteries connected with an ACR so that when I'm running the engine, I recharge both batteries. I bought the dual charger because of its dual nature and float feature to prevent overcharging. But now I'm thinking about how the ACR will interact with it since the ACR basically charges whichever battery needs charging the most. any insights? I also have a Blue Seas 5511E on-off-combine switch that I have not yet installed. I don't really want to have to disconnect battery cables when I'm using the charger. Thanks in advance.
    Bayliner 195 Bowrider 2013 4.3l 220hp MPI
    Alpha 1, Gen II
    2019 F-150 3.0l Powerstroke Crew Cab 4WD
    Albany, Ohio
    MMSI: 338234042
    King of retirement. Finally got that last promotion.
    Hey Nick - Amazing! I have almost the same situation coming in a few (or more) months when I start to rewire our Avanti 3685. I had originally purchased our Blue Seas ACR to do the dual bank charging on our 2452 but never got around to doing it before she was traded in on our Avanti. I did manage to install the new charger on the 2452 (yes, a two-bank charger) in under the helm seat and had plans for the ACR but that didn't happen. Now I get to do it on the Avanti . . . different boat - same idea though. I bought the item that has the unlatching switch with it with the full intent of "unlatching" the connection between the two banks when we left the boat for the weekend or extended periods of time and had the charger on shore power. I had asked this same question of the Board years back regarding the feasibility of using a one-bank charger since I would have the ACR in the system and most responded with a positive attitude thinking along similar lines. . . there were some who disagreed but don't really remember the reasons. This MAY be more of a project than I should undertake but I'm hoping to get a wiring layout soon (once I find out where to get one ) and have it all planned before the weather breaks in the Spring. As I remember, finding a single bank charger was one of the issues (believe it or not) . . . there's gobs of 2 and 3 and even 4 bank chargers out there. Anyway, I have the hydraulic crimper that I need, just need a few lugs and some cable and hope to start fairly soon. Good luck and keep in touch and maybe you (and others) can answer my questions when the time comes.
    1998 Avanti 3685 - "Dad's Dream" w 454 Mercs - for sale - Dredge Harbor, NJ
    Former - "Home Aweigh" 2003 - 2452 Bayliner Cierra Classic Hardtop Cruiser
    WQQM835 MMSI: 338147209
    James H. Stradling
      You could just hook up one of the battery charger outputs and do just fine.
      Hooking up both battery charger outputs won’t hurt anything, but with the ACR it’s not necessary
        I think a foolproof solution would be to use the existing battery switch after I install the new switch to disable the ACR when I'm charging with the new battery charger. There would be a small voltage drop across that switch when the engine is doing the charging but I could arrange for that to be to the house battery.
        in any case, I'm concerned that the ACR only isolates the two batteries when one of them is discharging...that's what the ACR documentation says, anyway. If both of them are being charged even if both are connected to the charger the ACR docs don't say what will happen, as I recall. I don't think anything disastrous will happen, but the "optimum maintenance" feature of the charger may not be operational. Additional thoughts are appreciated. I really want the best of both situations: engine charging both batteries via the ACR when underway and the charger without the ACR when on the trailer or at the dock on shore power (that may never happen and will certainly be rare; this boat doesn't sit in the water for more than a couple days without running).
        Dadrock, are you looking for someone to do a custom schematic for you?
        Alpha 1, Gen II
        Albany, Ohio
        MMSI: 338234042
          so you have a 2 bank charger and you can isolate (unlatch) the two banks whenever you leave the boat. That seems like what I want to do with a battery switch.
          Alpha 1, Gen II
          Albany, Ohio
          MMSI: 338234042
            the proper way to connect the charger to a system with an ACR is to connect ALL charging sources to the house bank, as the house bank takes the most abuse and usually needs charging the most, and let the ACR keep the start batt topped up..... the dual feed charger, im not sure what the amperage of the model you have is, but whatever the rating is, you have half of that rating number down each lead... you can either connect one lead to each battery, which will supply the amps in the lead to the individual batteries... OR... you can connect both leads to the same battery to get the full rated amps of the charger into the one battery. almost always, the output of both leads connected together on the same battery is how the charger is rated.
            connecting both charger leads to the house bank would be the proper way for the best performance, when using an ACR.... the alternator feed, the shore power charger, the genset charger and the solar charger should all connect to the same point and let the ACR do its magic....
            any and all of these charging sources are fully regulated, and the dominant charge source at the moment will take over the charging, while the non dominant chargers on th ecircuit will see this as a FULLY charged system and go in to float mode.... there are no worries of one charger damaging another...
            NU LIBERTE'
            Salem, OR
            5.7 OMC Cobra - 15.5x11 prop
            N2K equipped throughout..
              So the concept of a two bank charger is that there are two separate chgarging leads out of the charger that are isolated from each other when the charger is offline, and so that the total of the two charger leads is equal to the chargers rated capacity.
              If you just hook up one of the charging leads you still get the chargers full rated output capability. Now days it’s kinds tough to buy a battery charger with just one output.
                thanks, Kevin. One way or another I'll get it to work. Therapy!
                Alpha 1, Gen II
                Albany, Ohio
                MMSI: 338234042
                  Isn't the "smart charger" dual output logic such that it can bias the output amps so each battery is given what it needs ?
                  Example: 1 battery near full charge (3rd stage,float) and 1 that has been drained low as in a trolling or inverter use situation ( all 3 stages)?
                  " WET EVER "
                  mmsi 338108404
                  mmsi 338124956
                    Kevin is correct 2bank 20amp charger would be 10amp per bank.
                    each bank will go through the 3 stage process.
                      a dual or triple leg charger has "smart" charging capability, independently, on each leg.. but the advertised rating of the charger is DIVIDED between the number of output legs.... so if one wants the full charger capacity to charge only one battery, all of the legs need to be combined on the one battery. to get the full rated capability.. this is the way its always been, BUT i suppose its possible that a manufacture has started rating their chargers PER LEG...
                      this is why when someone has a dual or triple leg charger, and when they upgrade to an ACR to combine the charging of the multiple banks, ALL legs of the charger get combined with all other charging sources to the same bank.... which is recommended to be the house bank.
                      NU LIBERTE'
                      Salem, OR
                        yes... to the extent of its capability per leg..... but its capability is only 10amps per leg. so a "dual output" 20amp charger cannot not put its full 20 amps down one leg to charge the low battery, but the 10amps will be regulated "smartly" to bring the battery up to full charge in the most efficient manner...
                        NU LIBERTE'
                        Salem, OR
                          That is not always the case. Some chargers divide the output and some do not.
                          The Blue Seas 40 amp charger can output all 40 amps on one battery with one connection. The Xantrex truecharge2 as well. The Xantrex truecharge2 can even parallel two chargers together to make a larger charger, and add redundancy to the mix.
                          The Samlex is actually three chargers, so it divides as you indicated, as are some other brands.
                          It pays to carefully read the manual and keep in mind the intendended installation prior to buying a charger to make sure you are getting what you want.
                            Not all, but some newer smart charger
                            with Distributed battery technology will...
                            It Can deliver 100% of available amps to any one bank if needed
                              This issue came up when I asked my battery question.
                              https://www.baylinerownersclub.org/f...ry-bank-wiring
                              The ACR is designed to disconnect (cease functioning and isolate the two battery banks) if you disconnect its negative terminal. So if you've got a dual charger, you want to use this feature to disable the ACR whenever you're connected to shore power and using the charger. You can do this with a manual switch, or construct an automatic relay as explained here:
                              https://www.bluesea.com/support/arti...r_Interference
