Hi Guys:
Just got back from West Marine after waiting for a special order Navionics SD Card XG14-3....Apparently this is the only SD Card compatible with my Lowrance LCX-104C (2003 unit). However, when we plugged it in it didn't work. We went to main main screen, Map Data and went through each chart selection and none of them worked in the unit.
Anyone with this unit? If so what is the latest chart SD Card you are running with?
in advance
in advance
