Water in #7 Cylinder
    Many of you may have saw the post about the 2850 Contessa that was available. Well I am the lucky one that jumped on it. "Prequel" is a beautiful and well maintained and taken care of boat and the previous owners are absolute wonderful people. I can't say enough about them! So as you may remember there was water in #7 cylinder. She has been in the salt for the last 5 years so I presume Manifolds and Risers are due anyhow. My question, what other steps or tests do you suggest that I start with?
    BTW, I brought her up from Tacoma yesterday to Lake Washington and she ran beautifully.
    1986 2850 Contessa
    1994 350 (5.7) Mercury Mag
    290 Volvo DP
    Ted G
    The Great PNW
    86 2850 Contessa SB
    Designers Edition
    Mercury 350 Mag
    290 Volvo DP
    My first place to look is at the joint between the riser and the manifold. It’s the classic failure point as the walls thin out. If you got water in the oil, Seafoam and a few repeated oil changes will clean that right up. That it ran well under power says compression keeps the water out while the engine is running, but may allow invasion when shut down. Btdt. Pop the riser off and plug off the exhaust hose as you take a look. Parts are common and prices vary widely, even for the same part at different sellers. If you are a member of a boating, yacht club or RBAW, Fisheries will probably allow a discount. You just need to ask.
      Compression test and a cooling system pressure test is where I’d start. Like Pete said removing the exhaust components will give you a great visual of where the problem most likely is.
        On the one hand it could be a leaky gasket between the riser and exhaust manifold, on the other it could be that the riser or manifold has rotted through somewhere with the same result. In salt water 5-7 years is usually the time for at least inspection, if not replacement. When you get them off you want to look inside the exhaust ports to see if the exhaust valve stems look rusted. I'd also do a compression test because water in a cyl, can rust exhaust valve stems and this can cause a sticky valve and resultant rough idle due to loss of valve sealing when they close. Check for milky oil deposits under the valve covers, change oil as needed to get the moisture out.
        Long Island Sound Region
          Some pix, 1st is what milky oil under the valve cover looks like, second is what new sealing surfaces look like, last one is what exhaust ports/exhaust valves that are not rusted (manifolds/risers still good) look like.....the rust on the cyl head is because the gasket traps moisture...
          exhaust manifolds can be tested for leaks by filling them with Acetone (careful it is very flammable) it will find leaks that are very small because the surface
          tension is less than water...but at this point, I'd say replacement is the better way to go, Barr aftermarket is very good for the price.
          Click image for larger version  Name:	 Views:	2 Size:	14.1 KB ID:	405280Click image for larger version  Name:	 Views:	1 Size:	45.2 KB ID:	405281Click image for larger version  Name:	 Views:	1 Size:	102.7 KB ID:	405282
            If you know that water is getting into a cylinder you should not try starting it again. If there is water in it you run the risk of hydro locking a cylinder... very bad! It sounds like it may be OK so far so maybe you got lucky.
            1979 32 Uniflite Sport Sedan twin 270 crusaders
            2003 Bayliner 2152 210 Classic 5.0 mercruiser - sold
            I wish I knew now what I didn't know then
              Anytime you suspect water in a cyl the first thing you should do, is drain the block and manifolds, remove the spark plugs, ground the ignition and crank the engine over to blow out the water. Then spray fogging oil in the cyls and crank it over again. This is how I saved my engine when it had salt water in 2 cyls from blown head gaskets last year. I did this in September and when I took it apart a few months later, there was no rust in the cyls at all.
                Top end overhaul, I replaced the old heads with re-man marine 4.3 heads and Fel/Pro marine gaskets. Then added a new Volvo style center riser exhaust system.
                  Thank you for all the input. In a couple weeks hopefully I'll get a weather window and be able to start pulling it apart.
                  Ted G
                  The Great PNW
                  86 2850 Contessa SB
                  Designers Edition
                  Mercury 350 Mag
                  290 Volvo DP
                    At the very least #7 plug should be removed and the engine turned over to expel any water that may have been introduced after shut down. Then a shot of oil in the cylinder turning the engine over again. You don't want the rings to become rusted to the cylinder wall nor water to seep past the rings into the crankcase.
                      Dave the OP can correct me if I am wrong but in another thread when he found this boat for sale it had been sitting with this issue for about a year, therefore a few more months won't make a difference.
                        Didn’t catch that Mike, assumed the engine was currently in use and running. OP should definitely check the condition of the oil then.
                          Sorry Dave I was wrong, I found the other thread and the engine was running and the loss of cylinder 7 happened in the fall which is why the boat was sold. Anyhow he should check the oil as the engine has been ran this way. I agree with pulling the plug and turning it over to get any water out.
                            No worries, we'll wait to hear from the OP. I am curious to hear what the pressure readings on #7 are.
                              If it’s like a Sea Ray that I bought 15 years ago the water caused the valve seat on the exhaust to melt preventing it to seal and therefore the compression was zero. Reading the other post the P.O. says the engine ran well on 7 cylinders which is the same as the Sea Ray I had. Like you said we will just have to see what the OP uncovers.
