Temperature gauge calibration
    There seems to be a 10 degree difference between my US Marine original temp gauge and the temp from my IR gauge when read at the block. What could be the root cause, the gauge or the sender?
    Dave Stancil
    Bayliner #1 in slip
    1993 2859 Classic
    10 ' dingy w/4HP 2012 DS4 Suzuki
    Bayliner #2 in garage
    2000 19.5 Capri Classic on trailer
    My Maxum is the same. Best I came up with is weak grounding as the temp sensor is in the t-stat housing and the ground relies on brass eyelets in the gasket to provide ground but these go away over time due most likely due to dismilar metals.
      I would clean the connections, back of gauge also.
      Gauges are notorious for not being 100% accurate.
        I agree. Mine are the same, read many posts about these gauges being off to some degree. Your IR temp gun is more accurate. Also your engine temp will read the hottest at/near the t stat housing.
