Transducer Mounting
    Transducer Mounting
    Hi Group, I have a question on mounting an in hull transducer. Can a transom/trolling motor mounted transducer be converted to an in hull by gluing it in? Thanks, Jim
    Jim
    1975 2865 Carver Santa Cruz
    Twin 215hp 302 Ford Waukesha
    Twin Straight Shaft Drive
    Tow Vehicle 2002 Ford F250 Superduty
    7.3L Powerstroke
    Boise, Id
    Before attempting to glue it in, you can put the ducer in a zip lock bag full of water and securely place it in the bilge area to test it out. My transom mount ducer has been in my bilge this way all last season and apears to work just fine however I have lost the provision to read the water temp
      HI Dave did you glue it in or is the unit still in a bag? I would like to mount my Simmer transducer - Lowrance touch 2, any comments.
        The depth gauge and transducer doesn't have temp. If I need to know the temp I'll just put my hand in and it will tell me that it's too damn cold for an old guy to swim in.Jim
        Jim
        7.3L Powerstroke
        Boise, Id
          Haven’t stuck it down yet Fritz, it seems to work fine in the bag so I haven’t “fixed” it yet
            The motto, if it aint broke, leave it alone right Dave I need to learn that.
            • builderdude
              builderdude commented
              Exactly, it’ll get stuck down someday......
            I had 2 large bronze transducer in a fiberglass well in front od both engines for 10 years, worked great.
            Currently until I haul out this spring I have 3 Garmin transom mount transducers in the keel of my 3870, I raised the bilge pump a bit so there was water in the keel, works great.
              All good information, not working on the boat today -2 last night coming home from Helena, I know of topic but could not resist the rapid change form 52 Tue. afternoon to snow and -2 this morning Wed.
