I am confused as to why my wheel bearing fail every year. My boat weighs 7000 lbs and the current trailer is a 11,000 lb Tuff tandem made in Washington state. It has disk brakes with surge and a grease fitting in the front of the spindle which forces grease to the back bearing. I think it is a good set up, but each year I find water inside and the bearing are either rusted or caked with thick dry grease. I always use marine grease and try to never mix brands. I did notice this year that the same brand grease was a slight different color light blue than last years. I always use new bearings, races and seals. Should I re-grease at the end of the season as well as the the beginning ? Help Gary :livid:
Why are the bearings failing????-gctid401869
It is a good idea to also change out your races for the bearings. Not hard, plenty of youtube vids and I have some photos on my site when I did mine. Also pays to buy the best bearings, not the chinese stuff...
I also use a IR gun to check bearing temps ever time I stop... Good to see if a bearing is starting to be hotter than the other five...
Doug ;}
MMSI: 338068776
sigpic
with your setup you shouldn't have this problem as it's the best you can get here.
Disk brakes can run hotter and if you dunk the trailer into the water immediately after you drove for a while in an area where the trailer brakes were used quite a bit they may be hot.
Next thing is that the spindles could be aligned poorly but you would see this on the uneven wear of the tires.
Then the axle could be not square to the tongue. Measure from the center of the coupler to the tips of both spindles. Anything more than 1/8" and I would align it.
Last but not least and the easiest one. After packing the bearings and installing the wheels: did you press grease into the hub while rotating the wheel until grease came out all around the zerk fitting? If you don't do this there are air pockets in your hub, the assembly is hot when you dunk it and water will be pulled in through the rear seal. If you trailer a lot you should grease more often to make sure all grease loss (= air pockets) is replenished.
Oh, and one more thing. Did you get the correct seal? For the typical axle there are 3 different types available and the ID is different. If you use the wrong one you have a problem.
I had my last trailer for 6 years and trailered a lot. Never even repacked the bearings! Only exchanged the grease by pressing the old one out through the front.
Just once more: if you press grease into the zerk fitting slowly rotate the wheel at the same time!!!!!
Edit: just remembered. If you drove a long distance with up and down and you don't want to wait for the hubs to cool down shoot some grease into them until the almost liquid one comes out at the front. Fills all voids generated during the tow.
Thank you for the input. The information is spot on. I will fill the hub cavity with grease and see if that helps this year. The axles should be good because the tires are perfctly worn. Thanks again. Gary
GARCHAR
1988 2655
Twice Past Commodore
great if this was the only problem! I know, I know..... Rotate the wheel while filling it.....
Unfortunately it is sometimes fishing in the dark if you can't see the stuff. Then all possible problems have to be mentioned.....
To Go Aweigh 2452,
Doug,
You mentioned in a couple of discussions that you use an infared tool to check wheel temperatures, what readings to you get and do you aim at the hub where to bearings are or at the wheel. I just bought a tool and want to know what temperature to look for.
Cheers,
1997 2355
5.7 liter Alpha 1 Gen 2
Ladysmith Vancouver Island
Gary, my take on this;
Hubs/bearings are warm when we hit the water. As they cool, the pressure within the hub deminishes, and pulls a mild neg pressure.
Somewhere this wants to equalize, and the easiest area is usually at the seals.
The rubber caps should flex some and account for some of this, but I'll bet that they're not doing it.
I like the spindles that are ported to the inside. This cavity fills with the excess grease, and there's enough grease in this cavity to simply shift back and forth as the pressure changes, so water does not enter the hub area.
However, EZ Lube, Sure Lube, Super Lube aren't their doing spindles this way any longer... they're porting this back towards the hub cap.
So if the rubber cover isn't flexing to account for this, water is pulled into the hub area as to equalize.... or the cover is not sealing. Could be either.
boatworkfl wrote:
Whenever I stop while towing I reach down and feel the wheel hub for over heating, I also kick the tires.:kidding
2850Bounty wrote:
Is that in frustration because you had just burned your hand?:kidding
In my experience the defining factor on bearing longevity is the inner bearing seal surface condition.
If this surface is potmarked from corrosion, the best bearing system will fall flat on it's face. If this suface is in good condition, the bearings usually last 2+ years, which is all a guy can expect in the salt.
If yours are poor, I heard you can get a thin metallic cover which renews the surface...can't remeber the name....sorry.
Anyway, a bit of sandpaper will do the trick if they are lightly scored.
I've gone so far as to replace the axle to get good surfaces here because I couldn't keep the bearings in the trailer for 1/2 a year and for a long time couldn't figure out why after doing all the right things, bearing buddies etc....
Chay
