Mercruiser 5.0L exhaust flapper/shutter replacement
    2003 245SB 5.0L Mercruiser Alpha 1 Gen 2 exhaust shutter/flapper clacking noise on the starboard side, worn out. I plan to replace both sides in the spring, any advice that will save time/money/frustration/etc?
    Is this dry joint or wet joint exhaust?
    is there a riser between the exhaust manifold and the elbow? If so most find it easier to pull the manifold/riser/elbow as one piece as the studs holding them together make it hard to just pull the elbow.
      I leave the manifolds, spacers and elbows alone and remove the intermediate elbows only. Pretty simple on my boat as access back there is fantastic but not sure what it's like on your 245.
        Loosen the stainless clamps on the upper and lower boots completely and remove, use cordless drill for speed.
        Wear mechanic gloves and try to rotate the aluminum tube. You may have to use a screwdriver to pry the boots loose so you can rotate the tube. Push the lower boot down as far as you can. Push the upper boot up as far as you can. Then remove tube. May require wrestling a bit and beer breaks. It’s easy on a 2859 as I was able to stand in the engine bay.
        Esteban
        Huntington Beach, California
        2018 Element 16
        • builderdude
          builderdude commented
          Yep, aluminum tube = intermediate elbow.
