Installing a toilet, holding tank in a 1980 2650
    The Admiral says the next thing we need is a flushing toilet. She has had it with the porta potty.
    The toilet will be flushed with raw water (not from shipboard), into about a 28 gal holding tank with provisions to pump out or through a macerator pump overboard (when legal to do so). The 2650 is a trailerable boat and I think most time I will be dumping into an RV drain, however, I have never seen an adapter to go from a through hull to an flexible RV type hose.
    Does anyone have specific recommendations about :
    1) Toilet, must be tall, but not a big footprint with a water pump system to pull in outside water.
    2) Black water drain ideas for trailerable boat
    2650 Bayliner Explorer Express , 1980 model , single diesel; Isuza 4BDI, 280 outdrive,
    previous boats,
    Sea Ray 31, Tolly 48
    Great loop completed 2006
    10 year live aboard
    retired to land 2015
    rmitch
    I've been satisfied with my 5 oceans electric head so far. You could maybe plumb the system to allow the macerator to pump through a threaded deck type fitting but stopping off at the pump out before you retrieve the boat might be the way to go. That's what I do.
    link to electric head https://www.five-oceans.com/articulo...bowl-cover/728
      I did not know they made a conversion kit Dave! Thanks! The wife wants the electric version but i figured it would require replacing the whole assembly.
      so i guess you just converted the old oem jabsco pump style toilet to this? Was there any changes to the plumbing or was it a plug and play situation?
      I am also looking for something to be able to dump the tank after its on the trailer. No pump out station where we go up north here. Would be great to be able to pull into an rv dump station attach a hose and pump it out!!
      Doug
      496 big block - Bravo ll leg
      The Doghouse
      Prince George BC
        The electroc head was almost plug n play. Details on my thread.
        https://www.baylinerownersclub.org/f...thread-my-2556
        I think you could plumb in a Y valve on the discharge side of the Macerator and run it to a separate deck fitting to discharge like an RV. It'd just require a threaded coupler and some flexible hose. Not a bad idea now that I'm thinking about it
          Builderdude, This project starts with no head, the porta-potty is one of those hand carried units, so I am starting with no head to modify. That being said, what electric heads have members been pleased with? Displeased with?
          previous boats,
          10 year live aboard
          rmitch
          • builderdude
            builderdude commented
            The kit I posted just needs a bowl and lid to make it complete.
