I decided I needed to inspect it so I put a bore scope in it and this is what I found.
one of the areas looks like a possible leak. Pretty disgusting though. The black hose is the fresh water tank vent hose. It's supposed to be clear. You can also see the cork on the tank sender is pretty much rotten.
Any ideas on what's the best way to repair this? It's a 50 gallon tank. Aluminum. I guess I coukd have a new aluminum tank made. Probably cost about $700 to$1000.
I'm kind cleaning toward a bladder tank as there is one that will fit the space.
should I seal the floor back up or make it so I can access it.
