Hey all
My 97 2855 w 7.4L Merc Bravo III with 360 hours has developed a somewhat serious leak. When she is in the water (stored on the trailer) I have to run the rear bilge pump for about 30- 40 seconds every per 12 hour period to drain the rear bilge - not sure how much this equates to in gallons of water.. but its enough I would never leave the boat unattended for any length of time.
The only place I can seem to find water coming in is on the steering arm where it goes through the transom. It is wet on top of the arm - it doesn't appear to be flowing or running in.. it is just wet.
I have done some research and I guess it is common for the swivel shaft pin to corrode and cause the seal to fail and leak.
My questions are:
1. Do you all think this is the most likely cause of the leak?
2. Where and how should I look / test?
3. Is the fix I read about drilling into the outdrive a viable fix? Keep in mind, for me, cost is the most important factor.
The boat was a repo - I have had it for 3 years. I believe it came out of St. Augustine and sat in brackish or salt water.
Thanks.
My questions are:
Thanks.
