Legacy to new part number cross ref book
    Just finished another session trying to get cross reference P/N's for carpet and hull stickers. Can't find but a few items in the online manual. Guess they had to drop some P/N info to make room for these parts. which I NEVER knew were installed HaHaHa... thought y'all might get a chuckle from my frustration.
    From the 2002 revision:
    ST AID, ASPIRIN 31673NON-ASPIRIN - 500/BX1711971FIRST AID, NON-ASPIRIN 31674COLD PREPARATION 500/BX1711972FIRST AID, COLD PREPARATION 31675DECONGESTANT -500/BX1711973FIRST AID, DECONGESTANT 31676MUSCLE RELAXER- 500/BX1711974FIRST AID, MUSCLE RELAXER 31677THROAT LOZENGE- 500/BX1711975FIRST AID, THROAT LOZENGE 316821 PACK FORMA FIX GAUZE 3"-12 RL/PK1711976FIRST AID, 1 PACK FORMA FIX GAUZE 3" 316831 PACK FORMA FIX GAUZE 4"-12 RL/PK1711977FIRST AID, 1 PACK FORMA FIX GAUZE 4" 316843X3 GAUZE SPONGES- 100/BX1711978FIRST AID, 3X3 GAUZE SPONGES 31685AMMONIA INHALENTS- 10 EA/BX1711979FIRST AID, AMMONIA INHALENTS 31686STERILE EYE PATCHES- 50/BX1711980FIRST AID, STERILE EYE PATCHES 31687NON STICK PAD 3X4- 100/BX1711981FIRST AID, NON STICK PAD 3X4 31688MEDI RIP 1"- 24/BX1711982FIRST AID, MEDI RIP 1" 31689MEDI RIP 2"- 12/BX1711983FIRST AID, MEDI RIP 2" 31690TRIPLE ANTIBIOTIC OINT- 144/BX1711984FIRST AID, TRIPLE ANTIBIOTIC OINTMENT 31692HYDROCORTISONE CREAM 1 % - 144/BX1711985FIRST AID, HYDROCORTISONE CREAM 1% 31718-C#1 MAIN BOW EXTENSION1722686CANVAS, #1 MAIN BOW EXTENSION 31718-C 31719-ABOW RAIL FWD SECT F/31719 ASSY1722687CANVAS, BOW RAIL FWD SECTION ASSY 31719-A 31719-BSSTBD BOW RAIL HEEL F/31719 ASSY1722688CANVAS, STBD BOW RAIL HEEL ASSY 31719-BS 31719-DMID STANCHION @ 26" F/31719 ASSY1722689CANVAS, MID STANCHION AT 26" ASSY 31719-D 31719-EAFT STANCHION @ 24.5" F/31719 ASSY1722690CANVAS, AFT STANCHION AT 24.5" ASSY 31722CANVAS TOP BOW ASSY-CK891722691CANVAS, TOP BOW ASSY 31722 31722-DBOW EXTENSION, '891722692CANVAS, BOW EXTENSION 31722-D 31723-D1722693CANVAS, BOW BRACE 18.5" 31723-D 31737T-TRIM 11/16" WHITE (250'/SPOOL)1701413TRIM EDGE, T-TRIM 11/16" WHT 317492146MC LAMINATE ADHESIVE $64.35/PL1701414ADHESIVE, LAMINATE 31752LFT RING,LOCKING-SS-OFFST CAM UN1001701415LIFT RINGS/HANDLES, LOCKING SS 317557"-16 GRIT ZEC FIBER GRINDING DISC1711986ABRASIVE DISC, 7" 16 GRIT ZEC FIBER GRINDING
    Sold:
    Mariner 150
    Towing with:
    Near High Rock Lake, N.C.
    I’m accustomed to Boeing bills of material and the ones that were created on that version must have been done by McDonnel-Douglas. Even the most basic parts lists should be organized either by part type or goes-in-to. I’ve spent some time trying to fine part numbers that were appropriate for a given boat for members, and even had some success. However, it’s much more difficult than it should be. What are you looking for? I’ve done a lot of researching sources and may be able to point you to a supplier. Based on your post, about all you can get from that list is carpet color. The quantities for that kind of thing appear to be an uncut roll. Same thing for stripes. If they needed ten feet, they allocated a roll. The decals are easier in the aftermarket, try these guys. file:///var/containers/Bundle/Application/44AAAF41-8A95-40D6-9378-520F43D1EDD0/XfinityConnect.app/www.vinylapproach.com If you don’t see it, like I didn’t for my boat, send an email. Not only do they have the one I was looking for, I have my choice of colors.
      Thanks Pete, I'm going through the '90 parts manual, cross reference manual and 88 and 89 parts manuals running numbers between them and Google images and actually hitting upon things and getting more "fresh" numbers, but that streak's grinding down so I'll have a look. I got a chuckle out of some of the stuff they cataloged. I even saw several sizes of envelopes and employee counseling, medical, and time off forms. off forms in addition to the 1st Aid stuff above. I'm leaving all the tape stripes and the "Bayliner billboards" off the aft quarters and taking the side white all the way down the vertical for a more clean sleek look. To retain her "identity", I had the "2655 SUNBRIDGE" logos just fwd of where the arch mounts reproduced by Island Boat Lettering in NY and replacing the stamped CIERA (made of unobtainium, p/n 13579) on the upper aft tinted Lexan windows with slightly larger " stretched oval" ones. Being around aircraft my whole career, I find myself wanting all the data, info, warning placard stuff in place. When I do scale models I order all the no step, no push, etc. etc the kits don't come with and drive myself nuts for days placing them. I know...... I need help.....or shock therapy ​. I have the NMMA/ USCG medallion on it's way from NMMA and the VHF emerg. call instructions en route from USCG Aux. I found and ordered ignition and kill switch ( Donzi and Capri) with their appropriate readable silkscreened warnings ( ign, vapor, explosion, blower/ kill sw, qualified operator) that will blend well with the modified inst. pnl. and various other "common to all" placards. What I'm striking out on ( for now... that list will grow I'm sure) everywhere at present are the SEQUENTIAL LIFT HULL ( old p/n 6336, superseded by 1703791 ), the 5 YEAR HULL ( orig p/n 35861, repl from different year p/n 55662 ) which I thought about calling BL direct about since their superseded/ cross ref manual's last revision is April '09. Of what was there, what was left of my originals had to go when I started restoring the gel coat.
      Sold:
      Mariner 150
      Towing with:
        It looks like what they did was a data dump of all procurement items. Have you tried converting the file to excel? I haven’t tried it because I haven’t been bored enough.
          Well... I if it doesn't have rotors I'm a bit challenged.....shoot I'm still struggling with the new B.O.C format!
          Sold:
          Mariner 150
          Towing with:
