Part numbers needed for Manifolds/Risers/Elbows for 2005 Bayliner 245 5.0
    Rust appearing on the outside of the Elbow near the rubber boot. Also some surface rust on the riser on the driver side.
    Anyway have the parts or links for the replacements? Aftermarket is fine with me.
    You can call Mercruiser with your eng8ne serial number and they will give you the part number but this is easy just search for mercruiser 5.0/5.7 dry joint exhaust as they are all the same.
      Here’s a link to the 2bbl 5.0 through 2001. http://www.mercruiserparts.com/5-0l-...-1998-2001-0l0
      Merc parts are very serial number driven, so this will be close but may not be perfect. If you search Mercruiser parts there are several sites that have the same schematics and I believe Crowley lists aftermarket parts as alternatives on the parts sheet. It takes some patience and practice to zoom in then find out what part number 8 on the picture is on the parts list.
        I searched hard, and this is the best deal I found on exhaust for the sbc... all inclusive.
        https://www.ebay.com/itm/CHEVY-V8-EX...19.m1438.l2649
        NU LIBERTE'
        Salem, OR
        5.7 OMC Cobra - 15.5x11 prop
        N2K equipped throughout..
          I found this but not sure if its 7° or 14° for the elbow.
          https://www.ebay.com/itm/Barr-Manifo...NZRErV&vxp=mtr
          • Nauti_Mike
            Nauti_Mike commented
            These are dry joint
          • monello96
            monello96 commented
            Correct. Mine is the dry system on it. Will post pics at the bottom.
          That’s the value of the microfiche. The merc part number will provide the correct cross reference to other makers. It also why using your serial number is important.
            This link is for older wet joint exhaust and th3 OP has dry joint
              Old log style not dry joint
                Here is a complete kit 2 elbows, 2 mani's and all the gaskets 400 dollars.
                http://www.amarket.com/sbm3set.htm
                  Another wet joint set
                    Here is an OEM set, I’m sure if you search you can find better prices
                    https://nuwavemarine.com/oem-mercrui...yABEgKZBPD_BwE
                      Pic of the current system. Hoping I caught the issue in time.
                      • Nauti_Mike
                        FYI the part numbers are on the components. Also most kits do not include the spacers/risers so you will need to order them separately
                      What has everyone typically seen with these dry systems. Do the manifolds still need to be replaced or is it usually the risers that only need replacing. Im 1200 miles away from the boat and wont be back by it for 3 weeks. Was hoping to order the parts so they are ready before getting back down to Florida.
                        What problems are you experiencing? From looking at your photos, this appears to be an issue with the finish and not necessarily a mechanical issue. Are you leaking because it doesn't look like it. Absent a mechanical issue, treat it with some Ospho and repaint.
                        Mocoondo
                        2002 Bayliner 195 Capri
                        MMSI: 338091755
                          12 year old cast iron exhaust system on a raw water cooled Florida boat weather dry joint or not sould be completely replaced IMO.
                          • Nauti_Mike
                            100% agree
