Called home the other day to bad boat news.....all the oil leaked out of my engine while it's been sitting a couple of weeks. My father and brother inspected and found a hole due to corrosion on my base pan....which is the only corrosion on my engine thankfully. Guess it was poor quality and a bit of water in the bilge accelerated the rusting process.
2 questions so I can prepare accordingly:
1. Can I buy an automotive base pan and gasket to replace the old one on my VP AQ 260 (5.7 Chev) or do I need to order OEM or other marine part (ie. Sierra)??
2. In an '86 2556 flybridge, can the basepan be changed without lifting the engine? Pretty sure I can get all the bolts out but not sure I can fit the pan between the engine and stringer.
Any advice appreciated. Only have 5 weeks home to enjoy my boat and want to get her operational as fast as possible!!
