The fresh water pump, (Flojet 4405-143) , on my 3988 was really noisy and the vibration from the pump was rattling the hard plastic water lines. I initially thought about securing the water lines and going to a variable flow pump; however, after doing a little research, (this forum), I ended up installing a flexible water line loop on the supply side of the pump, (see picture). This flexible loop absorbs the vibration from the pump so it's not transferred to the lines. It's dramatic how this solution quieted everything down, including the pump itself. I understand that installing an accumulator will also perform this function.
Noisy fresh water pump and water lines
I think you meant the demand side.Jeff & Tara (And Hobie too)Lake Havasu City, AZ
|Current: 2022 Sun Tracker Sport Fish 22 XP3 w/ Mercury 200
And 13 others...
That is exactly what I did with my pump to reduce noise but the pictures are long gone with the changeover. Instead of an accumulator tank I went with the variable speed pump. The results are amazing because it eliminates the need for an accumulator tank and it eliminates the annoying temperature changes in the shower."Adios Dinero"
Photo Credit: Whiskywizard
- Likes 1
My boat's pump is fairly quiet, but this is not the case with my travel trailer. I used two loops of hose on my trailer's pump (demand and supply) to isolate it completely. Moreover, I added additional clamps to the first couple of feet of the rigid tubing. This made a huge difference in noise.1999 3788, Cummins 270 "Freedom"
2013 Boston Whaler 130 SS
Isla Verde, PR
- Likes 1
