Deck fill cap for waste fill tank on my 2855 is stuck. I've tried everything possible to get in unstuck without much success - WD40, PB, etc. I've even drilled out two holes in the cap, inserted grade 8 boltsin each hole. then used a bar between them for leverage to unscrew. No luck. I'll try once more, may be heat it up with blowtorch and give it couple of gentle knocks with a hammer, but I don't have much hope left.
Does anyone has expedience replacing waste deck fill on 2855 Bayliner Ciera?
