7.4 Mercruiser Raw Water Pump with Fuel Pump
    I am building a 496 Mercruiser with a Bravo and need to know if I can use a block mounted fuel pump? I want to eliminated the pump mounted to the belt driven raw water pump. I assume the reason for that was to use a mechanical pump on Gen V and VI big blocks that were not provisioned for a block mounted pump. My new engine is a MkIV and has the pad. I do not like the idea of such a small cavity for oil to lubricate the pump arm. Besides, the raw water mounted pumps are costly.
    1990 Four Winns 200 Horizon 5.7 OMC(sold)
    1989 Bayliner 2775 Ciera building 496 and Bravo 1 Mercruiser.
    Electric fuel pump would be the way to go.
    In my inexpert opinion.
      I agree with Chief on this. Not only would you need to open pad and tap holes to mount the pump I don’t think 5he new design has the eccentric that the pumps arm needs to ride on. The design you have has been around since 5ge mid 90s and works well as long as it’s maintained however maintance of 5e raw water pump is a PIA. Going to an electric pump is easy to do.
        May i also add, i would go with a crank mounted raw pump.
        Wasn't asked but just sayin ... if this were my engine, that's what i would do.
          Read the first post completely, he is building a Mark IV...........it has a mechanical fuel pump provision.
          Yes, you can do a mechanical pump and in the end would be the most cost effective. No oil pump switch interlock / safety etc..
          " WET EVER "
          mmsi 338108404
          mmsi 338124956
            Yes, I have a custom ground hydraulic roller cam and it has the pump lobe. I should be good to go.
              Your carb will also need to have a "ruptured diaphragm drain inlet" on it if not already equipped with one.
              " WET EVER "
              mmsi 338108404
              mmsi 338124956
                I will be using a marine mechanical pump with the proper vent to the carb
