Hi, we have a 1976 bayliner nisqually with a volvo penta outdrive. The flybridge steering wheel feels like it is coming loose from the fiberglass and starts to "skip" when turning left. Upon inspection we found that the screws for the wheel itself are all tight, but that there is a "shaft" that is coming from the wheel underneath the fiberglass that is fractured. The "shaft" has a horizontal bar attached to the end that connects to the steering cable. It appears that due to the fracture in the "shaft," that there is some play in the steering wheel, and that it may not be matching up with the gears that are in the horizontal bar that pull on the cable. I talked to a guy at West Marine, but he was clueless. Wondering if anyone knows what type of parts we would need to get to fix this problem. To me it seems that the steering cable is fine, and that we would just need to replace the cracked piece, but we don't know what the name of this part is. Any help would be appreciated.
