Volvo 275 transom shield change to DP ÔÇô A shield-gctid829096
    Looking to change transom shield from A 275 to DP-a shield. Anyone know what is involved, do I need to cut out the transom? Have a dual prop on the boat now but the last time I changed the intermediate housing in mount. I picked up everything dirt cheap with hydraulics and everything included. Anyone know how hard this swap?
    No offense....... but most people do not know the differences between the AQ series drives and/or what will interchange and/or what will NOT interchange.
    For example...... the Duo Prop (introduced in 1983) involves a change to the lower unit only........ and in most cases, the Intermediate housing and the transmission are the same as with the s/p drives.
    It would be best if you post photos of the existing and of what you propose to install.
    I can then offer you help.
      Ok taking is off
      replacing with this
      Want to change shield also
      Rick the drive I'm removeing you rebuilt the upper and lower about 5 years ago
        Well that didn't work to good
