Smartcraft Monitor SC1000-gctid828682
    Apologies if this has been covered off before - but extensive googling has not thrown up an answer....
    Installed a Smartcraft SC1000 monitor on my 2003 Mercruiser 4.3MPI - the unit is getting power and the software version flashes up (3.04) after that I only get zeros on the screen (some of which to be expected as engine not running) but I would expect to see engine hours flash up as well as Voltage and temperature - I have a suspicion that the software version (3.04) is too new for the PCM on the engine - am I on the right track? if this is the case can the PCM be re-flashed with a more up to date software version?
