Does anyone know if the top threads on the A/C pick up thru hull are NPT, NPS, or Hose Thread?
I've removed the A/C water pump but don't want to remove the thru hull in case the next owner want's to reinstall the A/C. I want to cap the valve for safety, but can't tell by looking the thread type.
The Bayliner part# is 62445 BALL VALVE, 3/4", W/GND SCREW. Same valve is used universally across most Bayliner boats of the time.
Thanks!
Thanks!
