Hello,
Got following issue with my '89 Ciera 3.0 with basic style (not star wars style
) instrument panel indicators.
I started the engine (cold climate, was hard start and needed several attempts), RPM indicator jumps to full RPM and stays there. Engine runs about 800-1000rpm. Then i shut down the engine after warmed up and switch power off, still stays on full rpm. I tried technical knock to the rpm indicator, that does not help. When boat was a few hours battery unconnected, rpm needle is back on normal 0 rpm. Is there some voltage staying in gauge or what is caused this problem?
