325SB (34)Dead(34) steering feel-gctid828143
    I've got a 2007 325SB with twin 350MAG MPI's that has developed a "dead" feeling in the steering. She tends to wander when underway at lower speeds, and drifts to port when at cruising speed (on plane, 25mph or so). This makes manuevering around the marina a bit touchy, and backing into my slip is a lot harder than it needs to be. She's always been a bit "loose" but it seems worse this season. Any thoughts? Thanks in advance!!
    Have you checked all the connections? I am not totally familiar with your exact system, bit I have had bolts loosen up, and mounting brackets come loose on different boats over the years.
    Joel
    1987 3818 Hino 175
    "Knotty Girl"
    Prince Rupert B.C.
      Check the transom assembly for side to side play. Common issue is a warn swivel shaft.
