I have a small water infiltration problem on the starboard side of my 1990 Ciera 2655. Water seems to come in from the arch and makes its way to the Aft cabin. The previous owners tried to fix the problem with expanding foam, but obviously it no longer works. Water was accumulating in the arch, so I took some of the caulking out to let the water out of the arch. I also sprayed some waterproofing rubber on top of the foam as a temporary measure, which seems to help, but still a bit of water coming in. Anyone with suggest a solution?
Also, believe it or not, I can't find replacement plastic caps (bolt holes covers) for the arch (Photo attached). Any leads?
