I noticed the nav lights were not working on my 185. I traced it down to a corroded fuse box terminal. Even the fuse itself has some corrosion on it but there is also no connectivity between the fuse receiptical and the post. I don't see corrosion in any other fuses but now I'm worried. Is this a sign that my other connections (i.e. ignition) could be corroding and I could end up dead in the water? Should I replace the entire fuse panel (I don't really use the nav lights)?
-Robert
-Robert
