I've got a 325 with the "standard" 15 inch Sole flat screen with DVD setup. This boat's TV is designed to be used for DVD movies, or cable TV. The boat did not come from the factory with a TV antenna. Now all non-cable TV is digital. What antenna is best and is a digital tuner required with the Sole 17 inch flat screen TV? When it comes to electronics, I need all the help that I can get. Any recommendations or suggestions are welcome! Griff
TV questions..need advice!-gctid400008
Read:
http://www.baylinerownersclub.org/fo...ne-TV-antennas
Then ask questions.
BTW, does the TV have a digital decoder built in? Many of the older ones did not and require a converter box ($40 at Wal mart). Without having DTV capibility, the antenna won't work.
Captharv 2001 2452
captharv wrote:
Read:
Then ask questions.
