Water heater, ac, cabin heater-gctid827239
    I recently got an 86 ciera 2550 st, and have been going over the boats features and locations of items. I discovered what I believe is the hot water tank on the port side of the engine bay. It's the type and is plumbed into the water cooling system. Starboard side has the macerator tank and pump. My real question is if the boat has the factory ac and heating system where would I locate them at. It seems to have come with every other option Bayliner has for the boat, except the generator. It may have all of the head tanks too, but that's for another post.
    Derby, Ct
    BOAT- Bout Oh Another Thousand
    1986 Bayliner Ciera 2550 St
    [color]blue wrote:
    I am not following you re; this one!
    A typical Marine type Water Heater will be found using 2 water heating sources.
    1....... A/C electricity via a Generator or via Shore Power
    2....... engine heat via the Water Heater's "heat exchanger" being plumbed into the engine's coolant system.
    [/color]
    [color]blue wrote:
    Suggestion:
    Take several good photos from within and around the Engine Bay and post them.
    [/color]
      So the A/C isn't under a dinette seat?
      Sold:
      Mariner 150
      Towing with:
      Near High Rock Lake, N.C.
