Hi Guys,
I know this may sound dumb to some, but for some reason I always thought I knew which battery was which.
The other day I was switching the battery switch and something made me doubt which battery is which in the battery compartment when the battery switch is selected.
Is there a quick way to know when I select battery #1 on the switch which is the battery in the engine compartment I am using. Is the one nearest the engine the #1 battery and the battery behind it nearest the hull wall battery #2. I have always assumed the one nearest the engine is battery #1. Can anyone concur? Is there a quick verification TEST method to prove out which is battery #1 & #2?
Ed
Ed
