Oil pressure gauge 2007 175-gctid399775
    I just changed the oil and filter onmy 2007 175 w/MerCruiser 3.0 . Now the Oil Pressure gauge won't register. I have checked all the fuses and all other gauges are working fine. Also the horn doesn't work either.
    Any suggestions or assistance is greatly appreciated.
    If it definatly worked before you may have knocked off the oil pressure switch wire on the engine. Now don't ask me where it is but look arround where you were working.
