Stiff steering wheel...-gctid826118
    I find very difficult to ride my brand new Element 160 boat at cruise or high speed. The steering wheel is particularly very stiff. The dealer seems to think everything is fine... Has anyone experienced a similar situation?
    Pierre B.
    Owner of a 2017 Bayliner Element 160
    Boating on Lake Provost in St-Donat, QC, Canada
    Maybe you can find a screw underneath the steering wheel box, some systems use this screw to put tension on the steering wheel so it won┬┤t turn if you take your hands off (cablesteering).
    Hydraulic steering tends to lock when you let go of the steering wheeel.
    1995 Bayliner 2452
    Alpha 1 Gen II
    2016 - 5.7 Vortec 4BBL
    Full Closed Cooling
      Thanks for your comment! I'll look underneath to see if I can find a way to loosen up the steering wheel.
      Pierre B.
        If its okay at low speed but seems to pull to the right and stiffen up at high speed then its a torque issue. Try trimming the motor out a bit and that should help.
        1988 Mainship 36 Sedan
        1995 2858
        1988 2655
        1987 2150
        Commercial/Industrial HVAC Service Tech.
          This is an outboard boat? I'd agree that drive trim angle will have a massive impact on the torque steer your experiencing.
