Just launched the 2650 after she set in barn for over seven years. I did all the service items and ran her with a muff before launch, the engine, the ISUZU 4BDI started and ran well. On launch, had some issue with the drive kicking up in reverse, but after running up trim up and down the lock held. After careful warm I ran the engine up and we comfortably ran at 1700 rpm and 6 mph (GPS), which is approximately hull speed. When I ran the engine up to 3000, which is the engine rated speed, she came up to 9 mph. It easily went to 3000 and could have gone more but I was out of Tach and being careful of an engine that sat for seven years. I suspect the prop is pitched to fine. This engine is capable of 80-100 hp and should take this boat on plane. Boat weighs about 5500.
The 280 outdrive has a tag on it, 284 9029 D, the propeller is a 15 inch, 3 blade. and no numbers for pitch, (I removed and looked at the hub) does anyone know the sterndrive ratio that might help me start figure out what the boat should have in order to plane? I will not operate the boat in plane often but would like to know I could if needed.
