Has anyone ever recharged their AC Units? I have a 1986 4588 motor yacht, Marine Air original equipment compressors, I think I found the recharge port, but not sure. Was told I could even use the same thing one would use to recharge car AC. Any suggestions will be appreciated. Thanks.
AC recharge-gctid825768
The only thing i can add is there are many different refrigerants that have been used over the decades and you cant mix and match. Some aren't available anymore.
It should have a label telling you what type it is.
1993 formula pc 31 twin 454 bravo 2
1989 2655 cierra 5.7 omc cobra
2014 "searay" tandom trailer
Anchor bay clinton river
Michigan
Of course if you need a recharge you have a leak. leaks let in moisture.
Any leaks should be found and fixed, Then you need to vacuum the system down to 29.9 inches of mercury ( you cannot get a perfect vacuum but it is pretty damn close.)
This will cause the moisture and air in the system to flash off and be evacuated. To do it right you would then give it a shot of nitrogen to break up any moisture or other gases clinging to the system
Vacuum back down to 29.9
Then recharge as per manufactures directions. If it is R12 you can convert to 134a (unless you live in California) BUT BGM is right, they don't mix.
Or
You can call in a AC mechanic and get it done right.
Boatless at this time
My marineairrrrr used R22. It is hard to get and the air guy I used said $30/pound. Mine had a leak and I filled it once. It lasted 7 months. Moreover, the unit was 16 yrs old, so I bought a new MARINAIR (No "e" is intentional). This company is an offshoot of the original which was bought by dometic and moved to Indiana. The offshoot units are great, I installed it myself. ( I am 70 years old and 5-6).It weighed about 30#, old one 60#. Mine had a 7000 BTU and was replaced with the new 6000 BTU. The new one is reverse cycle (old was air only) and comes with a digital wall control AND a handheld remote like a TV remote. It was about $1250 with tax and shipping. Works great and its quiet. Very quiet. The loudest sound is the air coming out of the return vent..
No middleman, you are dealing directly with a manufacture.
Installation: you need a drill, screwdriver, and wrenches. My installation was to remove the defective old unit and install the new on, retaining the hoses, raw water pump, the ducting, etc into the same location as the old one.
Note: I have no fiduciary ties with them; I just wanted to tell y'all about a great product.
www.marinair.com
Captharv 2001 2452
Or
Greg
Newport, Oregon
South Beach Marina
"Mr. Darcy" post=825917 wrote:
If there is any refrigerant remaining in the system prior to repair, it is supposed to be recovered using an approved recovery device and method. Easier to hire it done unless you are already in the HVAC trade.
Greg
...and can't help but wonder if either of them realized how toxic refrigerants are to breathe. It would be interesting to know the current state of health for the guy with the bolt cutters.
Newport, Oregon
South Beach Marina
Dunno , to get to my main workspace on board the Coast Guard cutter I had to pass through the refrigeration compartment.
I learned what the words Phosgene Gas means real quick.......
The unit you have would most likely have R-22. There are drop in replacement refrigerants available that would be compatible with the mineral oil that was used with 22. Sometimes its best to just replace a old tired unit as you can spend as much as 50% of the cost of a new one on repairs. Also dont just assume its low on refrigerant it could be a problem with the reversing valve if it is a reverse cycle heat pump. It could be the compressor is not pumping efficiently or a few other different things. The bottom line is have a qualified HVAC service tech check it out or apply the cost of that to a new unit.
1988 Mainship 36 Sedan
1995 2858
1988 2655
1987 2150
Commercial/Industrial HVAC Service Tech.
