Does anyone know where to check for the fuse on the macerator for a 99 byliner 2655? I turn it on and it went but then i let go of the bottom to check and then went to turn back on and it does nothing now so i have this on land and was cleaning tank since i don't want to put back in water since its all clean for the season. I turned the shaft on the motor and it turns but not very easy so is fuse under dash or is there one by the pump itself to check?
macurator fuse-gctid825757
