Started the alignment procedure today and i have it so the alignment bar slides in and out with 2 fingers............in one spot! Turn the motor over 180 degrees and its tighter. Bar still goes in and out but not as nicely. Fairly tight. Played with it for another few hours and can not get it smooth in all positions. 0- 90- 180- 270 degrees. New mounts all around. New transom and stringers and new hd coupler.
Could the coupler not be aligned on the flywheel? Not sure why it would be so good in one spot but tight 180 degrees from there.
