My Bayliner 2150 restoration is coming along. However, it will start when throttle is 3/4 to full and then stalls when you come back to neutral. Is this a timing issue or a throttle/cable issue? Thanks. I do not see a kill switch. 225 D inboard
Will not stay started-gctid825234
Could be the ignition timing is off or the carburetor idle circuit isn't getting any fuel, time for a carb rebuild maybe.
BTY no IAC as this is a carburetor engine.
