I NEED HELP WITH DIMENSION "X" in the pictures. I happened across a complete camper enclosure from an '88 2655 Ciera S.B. Mine only has the Bimini the fwd so I need the measurements for the fittings for the camper frame legs from the reference line aft as well as how far across the width of the nonskid Gunwale top where the rail, pump out, fresh water and fuel ports are. The '88 had the teak railing around the stern as does mine but folks parting the '88 out have been less than helpful as the said they would be with follow up info once I received the parts. I'm confident I could piece the enclosure together and get close but don't want to have a saggy top when finished. Sides and snaps are no prob as the canvas shop is leaving them for me to match/ install I will be posting two Biminis with front and side window zip ins and one complete frame associated with this project as well in classified, special parts and the 2655 Owner's sections. See picture for dimension needed. Thanks
