Hi Guys,
This is my 1st post. I have an 85 Bayliner 1710 Trophy Bass Boat with an 85hp Force Motor. I am putting in a new ignition switch cause previous owner had a mess with wiring. I have most of the wires connected but engine will not crank unless I jump a cable from the battery to the red cable from wiring harness. Not sure if I'm saying this correctly. Am I missing something or am I supposed to add a hot wire from battery to ignition switch. Any help appreciated. Wiring spec does not show wire from battery to ignition switch.
