"paul5150uk" post=824233 wrote:
Hi not at the boat and need to order some fuel hose can anyone tell me what size I need .
I have a 1989 2455 with 5.7l V8 omc cobra
Mine is https://www.walmart.com/ip/Shields-M... jacketed hose from the tank to the fuel pump. It has to be USCG approved. I'm just about to replace the line from the fuel pump to the carb when my new carb arrives. I'll be using the same A1-15, but will have a local shop add an 8" section of tube to it that has the correct fittings and a 90 degree bend.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
