Trophy 1802 FJ-gctid823653
    Hello All,
    I need to replace my throttle cable, and may do shift as well. The controller on this 1999 Trophy is a Commander 3000 and the outboard is a newish Merc 150 4-stroke OB. The existing (probably original) cable is a teleflex. From snooping around, it looks like I need a 15 foot cable, and it looks to be Gen I. Would a "Teleflex Mercury 600A" 15' cable fit?
    Also, can the cable's engine-end plastic connector and barrel be easily removed? I think it may simplify feeding the cable and getting it through the engine cowl (where all the other cables enter the OB).
