Bayliner 185 with 135 horsepower motor will not go over 2800 rpm-gctid823551
    I recently had my motor rebuilt with a new block as the old one cracked. Now the motor will not go over 2800 rpm. The motor is very sluggish. Does anyone have an idea, of what could be the problem?
    Definitely take it back to engine rebuilder in my opinion....
    Lake Hartwell, GA
    2012 BR 185 - 3.0 TKS
    1987 SeaRay 300 - Twin 454’s
    1995 Yamaha Waverunner III GP
    1996 SeaDoo GTX
    1999 SeaDoo GTX
      check compression, cam timing, ignition timing to start with.
      1987 Bayliner Trophy aq131a Red block VP 275?
        I would definitely take it back. I had a motor rebuild and ended up using a lower pitch prop to build rpm faster and get boat up on plane more easily.
        2007 288 Discovery Command Bridge
        Tacoma, WA
          Thank you for answering my question. I will be taking it back to the company that repaired the engine.
